Editing wall attributes
The wall attributes of an unstyled wall are initially set to the parameters displayed in the Attributes palette (see The Attributes palette). The opacity and drop shadow attributes are always set from the Attributes palette. If fill and pen are changed in the Wall Attributes dialog box, the Attributes palette reflects the changed attributes of the selected wall (after exiting the Wall Preferences dialog box).
Fill and pen attributes can be set by class rather than by the attributes in the Wall Attributes dialog box. If the wall class is changed later, the wall changes to use the attributes of the new class. Wall fill and pen attributes cannot be overridden on a per-instance basis; if a wall style uses class attributes, all walls of that style must use class attributes. However, walls of the same wall style can be placed in different classes.
To edit wall attributes:
From the Definition tab of the Wall Preferences dialog box, click Edit Wall Attributes to open the Wall Attributes dialog box.
Parameter |
Description |
Fill (standard walls only) |
Specify the wall fill attributes. Select a fill style, or select Class Style to set the fill attributes by class. Depending on the Style selected, select a color, pattern, or resource (hatch, image, gradient, tile) for the wall. |
Pen |
Specify the wall pen attributes. Select a pen style, or Class Style to set pen attributes by class. Depending on the Style selected, select a color, pattern, or line type resource for the wall. |
Thickness |
Select the line thickness; to use a custom thickness, select Set Thickness from the line thickness list (see Line thickness attributes) |
Make All Attributes by Class |
Sets all fill and pen attributes by class. Wall caps attributes are not affected. |
Remove by Class Settings |
Removes all by class settings for fill and pen attributes. Wall caps attributes are not affected. |
Below/Above Cut Plane Class |
To control appearance and visibility of the wall attributes below/above the cut plane when the wall uses the design layer cut plane, select a class from the list of classes present in the drawing, or create a new class. Select <Object Class> to use the wall’s class. See Setting design layer properties and Wall display with design layer cut plane. The fill and pen settings determine the appearance of the parts of the wall below/above the cut plane. The Above Cut Plane Class setting doesn't include parts of the wall at openings from inserts such as doors and windows. |
Add profile line |
Draws a profile line around the wall parts that intersect the cut plane in medium and high detail levels |
The wall can be set to use the design layer's cut plane; see Setting design layer properties, Standard wall preferences: Insertion Options tab, and Curtain wall preferences: Insertion Options tab. Symbols and plug-in objects can be set to use the wall's cut plane, ensuring a consistent appearance across the layer.
When the design layer cut plane is used, the following rules apply:
Walls are drawn as cut only to the extents intersected by the layer cut plane. The profile (when selected for the wall) is drawn as an outline only, using the wall’s pen attribute, emphasizing the cut plane while still allowing the components to be seen.
Wall portions above/below the cut plane are drawn using the attributes of the class selected in Below/Above Cut Pane Class in the Wall Attributes dialog box. Similarly, portions of wall features are drawn using the below/above cut plane attributes defined in their extents attributes.
Walls with components that create a flush surface in 3D are shown from above with caps and do not show the divisions between components. If some components are vertically offset from others, a line is drawn between them (similar to how they would show in a Hidden Line render mode). This is also true for walls above the cut plane.
Wall breaks (joins) are drawn only when both walls in the join area intersect the cut plane.
By default, windows and assemblies inserted into a wall are drawn normally when they pass through the cut plane, and with a simplified, non-breaking appearance when Show as clerestory when not in cut plane is selected. However, the attributes and visibilities can be customized for display above, at, and below the cut plane; see Window settings and Door and window assembly settings.
